Date/Time: Sat, 21 Dec 2024 13:22:06 +0000
Question about supporting reversals
View Count: 1091
[2015-04-11 00:32:23] |
User52239 - Posts: 13 |
I have "support reversals " set to true in the automated strategy code. Is there another setting needed to reverse positions from long to short , or from short to long ? e.g. when I have an open long position and a short signal happens, it ignores the short signal, even though I have support reversals set to true. This is ASCIL I am referring to. shane |
[2015-04-11 01:31:42] |
Possibly. Does the Trade >> Trade Service Log show a message at the time of the the short signal? If so, what?
[2015-04-11 01:42:43] |
no, there was no message. shane |
[2015-04-11 02:31:55] |
What function are you calling for the "short signal"? Refer to the documentation here for debugging: http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#DebuggingTradingSystems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-13 01:04:02] |
User120827 - Posts: 77 |
after trial and error testing, the code setting had to do with " allow entry with working order " it has to be set to true. It applies with spreadsheet settings also. |
