Date/Time: Wed, 17 Jun 2026 19:34:27 +0000
User Questions
View Count: 1075
[2015-04-10 23:59:40]
Sierra Chart - Max - Posts: 5943
1. How do I send a bracket OCO order for a limit and stop if I should loose them during
a trade in progress?
2. How can we install 2 different stop levels instead of having only 1 stop level if trading
multiple contracts?
3. Show how to see the P & L in Dollars instead of ticks if we want to use that.
4. How to stop the "confirm order" box from always popping up when a trade is entered.
5. Where do we go to see the list of buys and sells for the day, or for the week?
Sierra Chart Support
[2015-04-14 04:22:33]
1. This is documented here:
Attached Orders: Sending Attached Orders Independently
2. What you need to do is set the Attached Order Stop OCO Group to OCO Group 1. And then add another Stop order set to OCO Group 2. This is documented here:
Attached Orders: OCO Group (Group)
3. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ProfitLossDisplay
4. Refer to:
Basic Trading and the Trade Window: Main/C >> Menu (M) button
5. Refer to:
Trade Activity Log
Date Time Of Last Edit: 2015-04-14 04:23:22
