Date/Time: Sat, 21 Dec 2024 12:34:40 +0000
I reinstalled on a new pc & i can not conect from this installation :i get waiting to reconn
View Count: 898
[2015-04-10 13:48:19]
User462306 - Posts: 3
log
Software version: 1241 | 2015-04-10 13:41:41
Uses Old Spreadsheets | 2015-04-10 13:41:41
Enabled for: Advanced Features. | 2015-04-10 13:41:41
Enabled for: Sierra Chart Historical Data Service. | 2015-04-10 13:41:41
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-04-10 13:41:41
Active service: AMP/TTNet | 2015-04-10 13:41:41
Data/Trade Service Settings automatically set. | 2015-04-10 13:41:41
Time Zone: +00:00:00 (UTC+00) | 2015-04-10 13:41:41
2015-04-10 08:41:41 Local computer clock time | 2015-04-10 13:41:41
2015-04-10 13:41:41 GMT time | 2015-04-10 13:41:41
2015-04-10 13:41:41 Time zone adjusted time | 2015-04-10 13:41:41
Time difference to server time: 0 seconds. | 2015-04-10 13:41:41
Program path: C:\SierraChart\ampsc\ | 2015-04-10 13:41:41
Data Files path: C:\SierraChart\ampsc\Data\ | 2015-04-10 13:41:41
OS Version Number: 6.2 | 2015-04-10 13:41:41
Locale Information: C | 2015-04-10 13:41:41
Checking for new symbol settings for tt | 2015-04-10 13:41:41
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-04-10 13:41:41
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-04-10 13:41:41
Symbol settings are up-to-date for tt | 2015-04-10 13:41:41
AMP/TTNet | Connecting. | 2015-04-10 13:41:46
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:41:46
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-04-10 13:41:46
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-04-10 13:41:46
TT FIX Data socket (2) | Connected. | 2015-04-10 13:41:46
TT FIX Data: Sending the Logon message. | 2015-04-10 13:41:47
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:41:47
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:41:47
TT FIX Data socket (2) | Shutdown and closed. | 2015-04-10 13:41:47
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:41:47
TT FIX Data: Disconnected. | 2015-04-10 13:41:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:41:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:41:47
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:41:47
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:41:47
AMP/TTNet | Disconnected. | 2015-04-10 13:41:47
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:41:47
AMP/TTNet | Connecting. | 2015-04-10 13:41:52
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:41:52
TT FIX Data socket (3) | Connected. | 2015-04-10 13:41:52
TT FIX Data: Sending the Logon message. | 2015-04-10 13:41:52
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:41:52
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:41:52
TT FIX Data socket (3) | Shutdown and closed. | 2015-04-10 13:41:52
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:41:52
TT FIX Data: Disconnected. | 2015-04-10 13:41:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:41:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:41:52
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:41:52
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:41:52
AMP/TTNet | Disconnected. | 2015-04-10 13:41:52
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:41:52
AMP/TTNet | Connecting. | 2015-04-10 13:41:57
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:41:57
TT FIX Data socket (4) | Connected. | 2015-04-10 13:41:57
TT FIX Data: Sending the Logon message. | 2015-04-10 13:41:58
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:41:58
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:41:58
TT FIX Data socket (4) | Shutdown and closed. | 2015-04-10 13:41:58
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:41:58
TT FIX Data: Disconnected. | 2015-04-10 13:41:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:41:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:41:58
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:41:58
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:41:58
AMP/TTNet | Disconnected. | 2015-04-10 13:41:58
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:41:58
AMP/TTNet | Connecting. | 2015-04-10 13:42:03
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:03
TT FIX Data socket (5) | Connected. | 2015-04-10 13:42:03
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:03
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:03
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:03
TT FIX Data socket (5) | Shutdown and closed. | 2015-04-10 13:42:03
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:03
TT FIX Data: Disconnected. | 2015-04-10 13:42:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:03
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:03
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:03
AMP/TTNet | Disconnected. | 2015-04-10 13:42:03
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:03
AMP/TTNet | Connecting. | 2015-04-10 13:42:08
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:08
TT FIX Data socket (6) | Connected. | 2015-04-10 13:42:09
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:09
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:09
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:09
TT FIX Data socket (6) | Shutdown and closed. | 2015-04-10 13:42:09
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:09
TT FIX Data: Disconnected. | 2015-04-10 13:42:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:09
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:09
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:09
AMP/TTNet | Disconnected. | 2015-04-10 13:42:09
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:09
AMP/TTNet | Connecting. | 2015-04-10 13:42:14
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:14
TT FIX Data socket (7) | Connected. | 2015-04-10 13:42:14
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:14
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:15
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:15
TT FIX Data socket (7) | Shutdown and closed. | 2015-04-10 13:42:15
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:15
TT FIX Data: Disconnected. | 2015-04-10 13:42:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:15
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:15
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:15
AMP/TTNet | Disconnected. | 2015-04-10 13:42:15
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:15
AMP/TTNet | Connecting. | 2015-04-10 13:42:20
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:20
TT FIX Data socket (8) | Connected. | 2015-04-10 13:42:20
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:20
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:20
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:20
TT FIX Data socket (8) | Shutdown and closed. | 2015-04-10 13:42:20
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:20
TT FIX Data: Disconnected. | 2015-04-10 13:42:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:20
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:20
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:20
AMP/TTNet | Disconnected. | 2015-04-10 13:42:20
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:20
AMP/TTNet | Connecting. | 2015-04-10 13:42:25
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:25
TT FIX Data socket (9) | Connected. | 2015-04-10 13:42:25
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:25
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:26
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:26
TT FIX Data socket (9) | Shutdown and closed. | 2015-04-10 13:42:26
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:26
TT FIX Data: Disconnected. | 2015-04-10 13:42:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:26
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:26
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:26
AMP/TTNet | Disconnected. | 2015-04-10 13:42:26
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:26
AMP/TTNet | Connecting. | 2015-04-10 13:42:31
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:31
TT FIX Data socket (10) | Connected. | 2015-04-10 13:42:31
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:31
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:31
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:31
TT FIX Data socket (10) | Shutdown and closed. | 2015-04-10 13:42:31
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:31
TT FIX Data: Disconnected. | 2015-04-10 13:42:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:31
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:31
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:31
AMP/TTNet | Disconnected. | 2015-04-10 13:42:31
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:31
AMP/TTNet | Connecting. | 2015-04-10 13:42:36
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:36
TT FIX Data socket (11) | Connected. | 2015-04-10 13:42:36
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:37
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:37
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:37
TT FIX Data socket (11) | Shutdown and closed. | 2015-04-10 13:42:37
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:37
TT FIX Data: Disconnected. | 2015-04-10 13:42:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:37
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:37
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:37
AMP/TTNet | Disconnected. | 2015-04-10 13:42:37
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:37
AMP/TTNet | Connecting. | 2015-04-10 13:42:42
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:42
TT FIX Data socket (12) | Connected. | 2015-04-10 13:42:42
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:42
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:42
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:42
TT FIX Data socket (12) | Shutdown and closed. | 2015-04-10 13:42:42
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:42
TT FIX Data: Disconnected. | 2015-04-10 13:42:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:42
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:42
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:42
AMP/TTNet | Disconnected. | 2015-04-10 13:42:42
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:42
AMP/TTNet | Connecting. | 2015-04-10 13:42:47
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:47
TT FIX Data socket (13) | Connected. | 2015-04-10 13:42:47
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:48
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:48
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:48
TT FIX Data socket (13) | Shutdown and closed. | 2015-04-10 13:42:48
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:48
TT FIX Data: Disconnected. | 2015-04-10 13:42:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:48
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:48
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:48
AMP/TTNet | Disconnected. | 2015-04-10 13:42:48
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:48
AMP/TTNet | Connecting. | 2015-04-10 13:42:53
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:53
TT FIX Data socket (14) | Connected. | 2015-04-10 13:42:53
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:53
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:54
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:54
TT FIX Data socket (14) | Shutdown and closed. | 2015-04-10 13:42:54
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:54
TT FIX Data: Disconnected. | 2015-04-10 13:42:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:54
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:54
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:54
AMP/TTNet | Disconnected. | 2015-04-10 13:42:54
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:54
AMP/TTNet | Connecting. | 2015-04-10 13:42:59
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:42:59
TT FIX Data socket (15) | Connected. | 2015-04-10 13:42:59
TT FIX Data: Sending the Logon message. | 2015-04-10 13:42:59
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:42:59
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:42:59
TT FIX Data socket (15) | Shutdown and closed. | 2015-04-10 13:42:59
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:42:59
TT FIX Data: Disconnected. | 2015-04-10 13:42:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:42:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:42:59
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:42:59
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:42:59
AMP/TTNet | Disconnected. | 2015-04-10 13:42:59
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:42:59
AMP/TTNet | Connecting. | 2015-04-10 13:43:04
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:04
TT FIX Data socket (16) | Connected. | 2015-04-10 13:43:04
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:04
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:05
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:05
TT FIX Data socket (16) | Shutdown and closed. | 2015-04-10 13:43:05
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:05
TT FIX Data: Disconnected. | 2015-04-10 13:43:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:05
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:05
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:05
AMP/TTNet | Disconnected. | 2015-04-10 13:43:05
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:05
AMP/TTNet | Connecting. | 2015-04-10 13:43:10
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:10
TT FIX Data socket (17) | Connected. | 2015-04-10 13:43:10
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:10
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:10
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:10
TT FIX Data socket (17) | Shutdown and closed. | 2015-04-10 13:43:10
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:10
TT FIX Data: Disconnected. | 2015-04-10 13:43:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:10
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:10
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:10
AMP/TTNet | Disconnected. | 2015-04-10 13:43:10
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:10
AMP/TTNet | Connecting. | 2015-04-10 13:43:15
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:15
TT FIX Data socket (18) | Connected. | 2015-04-10 13:43:15
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:15
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:16
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:16
TT FIX Data socket (18) | Shutdown and closed. | 2015-04-10 13:43:16
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:16
TT FIX Data: Disconnected. | 2015-04-10 13:43:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:16
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:16
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:16
AMP/TTNet | Disconnected. | 2015-04-10 13:43:16
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:16
AMP/TTNet | Connecting. | 2015-04-10 13:43:21
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:21
TT FIX Data socket (19) | Connected. | 2015-04-10 13:43:21
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:21
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:21
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:21
TT FIX Data socket (19) | Shutdown and closed. | 2015-04-10 13:43:21
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:21
TT FIX Data: Disconnected. | 2015-04-10 13:43:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:21
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:21
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:21
AMP/TTNet | Disconnected. | 2015-04-10 13:43:21
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:21
AMP/TTNet | Connecting. | 2015-04-10 13:43:26
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:26
TT FIX Data socket (20) | Connected. | 2015-04-10 13:43:26
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:27
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:27
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:27
TT FIX Data socket (20) | Shutdown and closed. | 2015-04-10 13:43:27
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:27
TT FIX Data: Disconnected. | 2015-04-10 13:43:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:27
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:27
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:27
AMP/TTNet | Disconnected. | 2015-04-10 13:43:27
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:27
AMP/TTNet | Connecting. | 2015-04-10 13:43:32
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:32
TT FIX Data socket (21) | Connected. | 2015-04-10 13:43:32
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:32
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:32
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:32
TT FIX Data socket (21) | Shutdown and closed. | 2015-04-10 13:43:32
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:32
TT FIX Data: Disconnected. | 2015-04-10 13:43:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:32
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:32
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:32
AMP/TTNet | Disconnected. | 2015-04-10 13:43:32
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:32
AMP/TTNet | Connecting. | 2015-04-10 13:43:37
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:37
TT FIX Data socket (22) | Connected. | 2015-04-10 13:43:37
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:38
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:38
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:38
TT FIX Data socket (22) | Shutdown and closed. | 2015-04-10 13:43:38
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:38
TT FIX Data: Disconnected. | 2015-04-10 13:43:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:38
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:38
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:38
AMP/TTNet | Disconnected. | 2015-04-10 13:43:38
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:38
AMP/TTNet | Connecting. | 2015-04-10 13:43:43
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:43
TT FIX Data socket (23) | Connected. | 2015-04-10 13:43:43
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:43
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:43
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:43
TT FIX Data socket (23) | Shutdown and closed. | 2015-04-10 13:43:43
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:43
TT FIX Data: Disconnected. | 2015-04-10 13:43:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:43
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:44
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:44
AMP/TTNet | Disconnected. | 2015-04-10 13:43:44
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:44
AMP/TTNet | Connecting. | 2015-04-10 13:43:49
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:49
TT FIX Data socket (24) | Connected. | 2015-04-10 13:43:49
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:49
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:49
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:49
TT FIX Data socket (24) | Shutdown and closed. | 2015-04-10 13:43:49
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:49
TT FIX Data: Disconnected. | 2015-04-10 13:43:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:49
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:49
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:49
AMP/TTNet | Disconnected. | 2015-04-10 13:43:49
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:49
AMP/TTNet | Connecting. | 2015-04-10 13:43:54
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:43:54
TT FIX Data socket (25) | Connected. | 2015-04-10 13:43:54
TT FIX Data: Sending the Logon message. | 2015-04-10 13:43:54
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:43:55
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:43:55
TT FIX Data socket (25) | Shutdown and closed. | 2015-04-10 13:43:55
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:43:55
TT FIX Data: Disconnected. | 2015-04-10 13:43:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:43:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:43:55
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:43:55
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:43:55
AMP/TTNet | Disconnected. | 2015-04-10 13:43:55
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:43:55
AMP/TTNet | Connecting. | 2015-04-10 13:44:00
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-04-10 13:44:00
TT FIX Data socket (26) | Connected. | 2015-04-10 13:44:00
TT FIX Data: Sending the Logon message. | 2015-04-10 13:44:00
TT FIX Data: Received a Logout message. Text = Username / Password not recognized. | 2015-04-10 13:44:00
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2015-04-10 13:44:00
TT FIX Data socket (26) | Shutdown and closed. | 2015-04-10 13:44:00
TT FIX Data: Logged out and disconnected. | 2015-04-10 13:44:00
TT FIX Data: Disconnected. | 2015-04-10 13:44:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-10 13:44:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-10 13:44:00
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:44:00
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:44:00
AMP/TTNet | Disconnected. | 2015-04-10 13:44:00
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-10 13:44:00
File >> Disconnect selected. | 2015-04-10 13:44:03
TT FIX Data: DisconnectFIX called. | 2015-04-10 13:44:03
TT FIX Trading: DisconnectFIX called. | 2015-04-10 13:44:03
AMP/TTNet | Disconnected. | 2015-04-10 13:44:03
[2015-04-10 14:14:43]
ok, amp reset and now is conecting
[2015-04-10 17:12:57]
Problem considered solved.
