Date/Time: Sat, 21 Dec 2024 12:44:38 +0000
Pricing order flow footprint
View Count: 2251
[2015-04-10 09:18:56] |
User360161 - Posts: 1 |
Hello I have some question Do sierra charts has his own order flow ( footprint) indicator??? in its plateform?? Or you have to purchase it to another seller?? I use market profile and order flow, Which will be the cost of the platform and these two tools?? I think the data i can use the cqg of amp futures, isnt it?? Sorry for my typing errors... Thanksss |
[2015-04-10 17:44:21] |
Sierra Chart has a Numbers Bars feature which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php This is included with Sierra Chart Service Package 5. Pricing can be found on this page: Description of Service Packages and Pricing Sierra Chart does support CQG and AMP: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
