Date/Time: Sun, 22 Dec 2024 01:44:56 +0000
Add 15 m default
View Count: 942
[2015-04-10 01:22:03] |
User78439 - Posts: 21 |
Under menu, we have 1M, 5M, 10M, 30M, 1H button to choose time frame for a chart. It is possible to add 15M time frame ? If yes, how to do that ?
[2015-04-10 07:11:45] |
Kiwi - Posts: 375 |
Yes Global Setting >> Customize Menu Items >> Main Menu >> Chart >> Bar Periods and pick 15 Date Time Of Last Edit: 2015-04-10 07:25:26
[2015-04-10 07:32:26] |
No, the menu cannot be changed but you can add a custom ToolBar button: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
