Date/Time: Thu, 10 Sep 2026 20:13:44 +0000
Not connected
View Count: 1364
[2015-04-10 01:09:08]
User78439 - Posts: 26
I purchased a package 3 and I chose SC historical data. In pricing, it seems that it is included. But inside SirraCharts, service, it is shown: SC historical data(Not enabled on package) and on right upper corner, I see a RED message: Not corrected.
I purchase this package for back-testing. Why I could get SC historical data ?
Thanks for your help.
[2015-04-10 01:12:41]
You added 27 USD to the Additional Services Balance. We are purchasing the usage time for you. Restart Sierra Chart.
[2015-04-10 01:28:25]
Thanks, it works now.
In addition, when I use it during trading hour, I can get just DELAYED data in chart ?
[2015-04-10 01:30:36]
Yes, the data will be delayed 10 to 15 minutes but it will not update unless you reconnect to the data feed.
[2015-04-10 01:43:56]
That means I have to refresh manually to update data ? If I choose 30M time frame, each 30m, I need to reconnect the data feed ?
[2015-04-11 08:58:09]
Yes, this is a correct understanding and keep in mind at the time of reconnection the data will be delayed 10 to 15 minutes.
Date Time Of Last Edit: 2015-04-11 08:58:24
[2015-04-12 01:07:45]
I tried Friday, it worked really like this : I had to reconnect manually every 30m to get delayed data. It is a little boring if I want to stay connected. There is other way so that it can update automatically ?
[2015-04-12 05:03:37]
No other way.
