Date/Time: Sun, 21 Jun 2026 00:37:36 +0000
VbP: All bars in chart mode does not respect always keep in view or align far right
View Count: 1238
| [2015-04-09 22:50:05] |
| i960 - Posts: 360 |
Title says it. Using "all bars in chart" forces the VbP to hug the last bar of the session rather than using the fill space regardless of keep in view or not. A larger VbP would more likely be desired in the fill space rather than the last bar of a session. The only way I can get this to work is to change to a monthly period - but then I'm screwed at the beginning of the month. Note: this is with right alignment. |
| [2015-04-10 08:45:34] |
OK we will see if we can quickly fix this.
