Date/Time: Sun, 22 Dec 2024 01:57:40 +0000
[User Discussion] - Bar Times
View Count: 803
[2015-04-09 17:20:32]
User15952 - Posts: 132
I cannot find where to change the bar time to display as the end time as opposed to beginning time.
As an example the opening 5 minute bar of the day is displayed at 9:30. I would like for it to display as 9:35.
The market end time of the e-mini should be 16:15 and NOT 16:10.
[2015-04-09 17:28:34]
This is not supported.
[2015-04-09 17:35:19]
That is crazy. You are aware that this is a fundamental flaw. Is it a priority on the development list of things to do?
[2015-04-09 21:54:25]
i960 - Posts: 360
Just use the next bar if you want to determine the current bar's end time. Additionally, end of session time is obvious. Out of curiosity, why do you require this bar end time display?
