Date/Time: Sun, 22 Dec 2024 01:54:09 +0000
Enable Bulk Data Download in Trial?
View Count: 791
[2015-04-09 13:40:44] |
User213277 - Posts: 1 |
I would like to demo the bulk data download, but I get the following message: This feature is not supported in the version of Sierra Chart you are running. | 2015-04-09 08:39:40 * I'm running Version 1246 and updated it today. |
[2015-04-09 16:25:59] |
This feature is not supported in any version. It is for internal use only.
