Date/Time: Sat, 21 Dec 2024 17:15:23 +0000
eurex dax
View Count: 972
[2015-04-09 06:15:36] |
User60358 - Posts: 47 |
charts of futuire dax - eurex doesn' t run
[2015-04-09 06:31:06] |
We are checking on this. We are told the collocation facility had some kind of power interruption. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-09 06:39:18] |
We are still working on the problem. It may help to switch to our other server. To do this select File >> Disconnect and File >> Connect to Data Feed.
[2015-04-09 06:53:16] |
I swiched but it doesn't work
[2015-04-09 07:01:54] |
How about now?
