Date/Time: Sat, 21 Dec 2024 16:50:58 +0000
when scrolling chart becomes unreadable. regardless of range setting
View Count: 846
[2015-04-08 23:30:47] |
User21339 - Posts: 61 |
a little difficult to explain..but the attached gu chart shows what happens when i scroll out too far. happens on laptop and large monitors. the data becomes unreadable if scrolled out beyond approx 100bars. http://www.sierrachart.com/image.php?l=1428535547116.png |
[2015-04-09 00:44:05] |
Re-download the data in the chart with Edit >> Delete All Data and Download
