Date/Time: Sat, 21 Dec 2024 17:17:38 +0000
TRADE IN REAL TIME AND BACKTESTING AT THE SAME TIME?
View Count: 861
[2015-04-08 17:49:07] |
User82615 - Posts: 106 |
HELLO I HAVE A QUESTION: IWOULD LIKE TO BE ABLE TO TRADE AND DO BACKTESTING AT THE SAME TIME BUT I THINK THAT THIS IS IMPOSSIBLE SINCE TO DO BACKTESTING I HAVE TO DISCONECT SIERRACHART FROM THE DATA FEED SO IF I AM BACKTESTING I CAN'T TRADE AND IF I AM TRADING I WON'T BE ABLE TO DO BACKTESTING SINCE THE DATA FEED WILL BE CONNECTED. IS THERE ANY WAY TO DO THIS? , THE ONLY THING THAT I CAN THINK OF IS TO HAVE TWO DIFFERENT ACCOUNTS IN SIERRA CHART, SO IN ONE I CAN DO BACKTESTING AND IN THE OTHER I CAN TRADE IN REAL TIME IS THIS RIGHT? DO YOU RECOMEND ME TO HAVE TWO DIFFERENT ACCOUNTS IN SIERRACHART? THANK YOU VERY MUCH |
[2015-04-08 18:01:03] |
This is supported by installing another copy of Sierra Chart and using that for back testing: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html#StepByStep Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
