Date/Time: Sat, 21 Dec 2024 13:20:50 +0000
keyboard shortcuts for newer 'Bar Period Types'
View Count: 972
[2015-04-08 17:02:30]
GrigorHagop - Posts: 18
Are there any keyboard shortcuts (e.g. [#][type letter][return]) for the newer Bar Period Types. For example, I found accidentally that [type letter]=R will provide ‘Range per Bar – Standard (in ticks)’.
Is there a keyboard letter short cut for the Reversal Bar (in Ticks), that is the old point & figure in bar format? Also, are there letter designations for obtain ‘Range per Bar’ other than the 'Standard'? I thank you in advance for your help and for the amazing amount of program enhancements you have provided.
Date Time Of Last Edit: 2015-04-08 18:32:23
[2015-04-10 18:08:01]
We have to think about this.
