Date/Time: Mon, 30 Dec 2024 17:38:32 +0000
$SHBI & $SLVI do not update in Sierra Chart correctly
View Count: 893
[2015-04-08 14:36:42] |
User778305 - Posts: 1 |
Hello, Can you please help me fix this. I have attached my subscription overview from IB and the log file. |
log.txt - Attached On 2015-04-08 14:35:18 UTC - Size: 48.74 KB - 357 views marketdata.png / V - Attached On 2015-04-08 14:35:22 UTC - Size: 24.07 KB - 311 views Attachment Deleted. |
[2015-04-08 17:20:47] |
Those are Sierra Chart symbols and not Interactive Brokers symbols. You need to use the proper Interactive Brokers Index symbols. Refer to: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Index Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-08 17:20:56
