Date/Time: Tue, 15 Sep 2026 00:38:47 +0000
Depth of market study
View Count: 2523
| [2015-04-08 10:00:36] |
| nicktrader - Posts: 811 |
The study show only the best bid/offer level. Is it possible to add all levels of a DOM?
| [2015-04-08 16:42:44] |
The study will display all market depth levels available for the symbol and provided by the service. Do you see all of the levels in Chart >> Open Market Depth Window? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-09 06:20:09] |
Yes, I do as you can see in the attached file.
| [2015-04-10 17:39:25] |
We are not seeing a problem with this. You can see the data being outputted to the spreadsheet when the Spreadsheet study is added to the chart. Refer to the attachment.
| [2015-04-11 11:33:28] |
| Spinoza - Posts: 62 |
See the following thread: Depth of Market Data Study on new spreadsheets | Post: 48269 There was a problem which was fixed in version 1243 so probably the solution is to upgrade to that version or later.
| [2015-04-11 19:14:24] |
many thanks. I thought you can see each single levels with its own ID # in the study. Is it possible to add the sum and the percentes line - as seen in the "Open Market Depth Window" - with its own ID#? It would be very helpful. |
