Date/Time: Sat, 21 Dec 2024 17:18:53 +0000
IB Stop Order Trigger Method
View Count: 1301
[2015-04-08 03:33:47] |
rc7rader - Posts: 144 |
On Data/Trade Service Settings Trade Settings, there is an option to set IB Stop Order Trigger Method. The selection are numbers 0 to 8. What do these numbers mean? Also, will setting the stop order method on Sierrachart override the default on IB TWS? The reason is sometimes I want a default trigger method of Last and sometimes I want Double Last and it seems easier to set it on Sierrachart if it will override IB TWS default stop trigger method. |
[2015-04-08 17:36:34] |
This is documented here: http://www.sierrachart.com/index.php?page=doc/IB.php#IBStopOrderTriggerMethod Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
