Date/Time: Sat, 21 Dec 2024 17:04:20 +0000
'Study Subgraphs studies' chart region bug in build 1244 and 1245
View Count: 818
[2015-04-07 21:25:20] |
User22396 - Posts: 191 |
In build 1244 and 1245 the 'study subgraphs studies' will not allow the chart region to be changed...it is grayed out build 1243 allows the selection of a chart region when applying the study. thanks |
[2015-04-07 22:56:45] |
We are fixing this now.
[2015-04-08 01:52:12] |
This has been corrected. Update Sierra Chart with Help >> Download Prerelease.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-08 01:52:30
