Date/Time: Thu, 10 Sep 2026 22:08:54 +0000
V1245 compile issue
View Count: 1295
| [2015-04-07 20:34:11] |
| ertrader - Posts: 698 |
Hi Support, When compiling with V1245, I get the following error message saying a file is missing. This happens with any source file I attempt to compile. Can you please take a look? -- Starting build of Custom Studies Source files: C:\SierraChart\ACS_Source\AutoTradeSignalV4.cpp. -- 15:27:56 Source file "C:\SierraChart\ACS_Source\C:\SierraChart\ACS_Source\AutoTradeSignalV4.cpp" is missing. -- End of Build -- 15:27:56 |
| [2015-04-07 21:04:52] |
We are fixing this now.
| [2015-04-09 14:10:02] |
This issue is still happening with V1246. Can you please fix? -- Starting build of Custom Studies Source files: C:\SierraChart\ACS_Source\AutoTrendHist9.cpp. -- 09:08:31 Source file "C:\SierraChart\ACS_Source\C:\SierraChart\ACS_Source\AutoTrendHist9.cpp" is missing. -- End of Build -- 09:08:31 |
| [2015-04-09 16:50:33] |
Select Analysis >>Build Custom Studies DLL. Press the Select button on the Build window and reselect the file. This will solve the problem.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-09 16:50:45
