Date/Time: Thu, 10 Sep 2026 22:17:53 +0000
I'm new to seirra charts and was wondering how does one get historical bidvolume and ask volume
View Count: 1279
[2015-04-07 17:59:12]
User512347 - Posts: 5
I saw that in your packages for sierra data services you provide historical bidvolume and askvolume. Can i get this for equities? I have access now to the data feeds for the appropriate exchanges. Also can this be seen when using a specific study such as number bars calculated...it should show the historic bidvolume and askvolume? If not how does want pull this data up via a study or something else.
[2015-04-07 18:47:36]
Historical bid volume and ask volume is provided for US equities when using the Sierra Chart Real-time and Historical Exchange Data Feed.
Your account is properly activated for this data feed. You need to set the Global Settings >> Data/Trade Service Settings >>Service in Sierra Chart to "SC Exchange Data" to use this data feed.
Numbers Bars Calculated Values will work properly with this data feed.
[2015-04-07 19:27:02]
Ok I see that the numbers bars calculated is working however it is only showing from the Start of Today for most equities. Basically no historic data. However, for example, for some reason Google stock is showing numbers bars calculated historic data from many days previous. Just trying to determine when I look at stocks like aapl, or amzn no data but for today however I pull up google and its plotted correctly. Any advise?
[2015-04-07 22:57:49]
Re-download the data with Edit >>Delete All Data and Download.
