Date/Time: Sat, 21 Dec 2024 16:34:22 +0000
alert formula
View Count: 1021
[2015-04-07 14:23:49] |
mayerrs - Posts: 70 |
hi, is possible to have more than 1 alert formula in chart settings > alerts ? if yes, how should i separete these 2 formulas? thank you |
[2015-04-07 16:19:30] |
Sierra Chart - Max - Posts: 5756 |
If you want the alert to trigger when both formulas are true use: =AND(Formula1,Formula2) If you want the alert to trigger when one formula is true use: =OR(Formula1,Formula2) For more details sees: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#AlertConditionFormulaFormat Sierra Chart Support |
