Date/Time: Fri, 22 Nov 2024 18:35:43 +0000
euro fx
View Count: 1578
[2013-05-31 11:25:18] |
User28317 - Posts: 149 |
The symbol for the e mini Euro fx is "E7" on your system. I have not been able to pull up a chart. Says symbol not found. What am I doing wrong? Kelly |
[2013-05-31 18:04:11] |
We see you are using DTN IQ Feed. Please contact DTN for the correct symbol.
