Date/Time: Mon, 30 Dec 2024 17:56:10 +0000
Continuous contract limitation
View Count: 906
[2015-04-07 05:33:32] |
xRoads1 - Posts: 35 |
I am limited to 5 years of continuous in loading /ESM5 back adjusted data from my TD Ameritrade account using Sierra Chart Real-Time and Historical Exchange Data Feed. Is there a way to get more? Here is the log stating that limitation: Limiting the number of years back for the continuous futures chart to 4.9993155. Reason: Single-digit year in symbol. | 2015-04-07 01:21:21 Date rule based rollover from /ESM0 to next contract occurs at 2010-06-10. | 2015-04-07 01:21:21 Date rule based rollover from /ESU0 to next contract occurs at 2010-09-09. | 2015-04-07 01:21:21 Date rule based rollover from /ESZ0 to next contract occurs at 2010-12-09. | 2015-04-07 01:21:21 Date rule based rollover from /ESH1 to next contract occurs at 2011-03-10. | 2015-04-07 01:21:21 Date rule based rollover from /ESM1 to next contract occurs at 2011-06-09. | 2015-04-07 01:21:22 Date rule based rollover from /ESU1 to next contract occurs at 2011-09-08. | 2015-04-07 01:21:22 Date rule based rollover from /ESZ1 to next contract occurs at 2011-12-08. | 2015-04-07 01:21:22 Date rule based rollover from /ESH2 to next contract occurs at 2012-03-08. | 2015-04-07 01:21:22 Date rule based rollover from /ESM2 to next contract occurs at 2012-06-07. | 2015-04-07 01:21:22 Date rule based rollover from /ESU2 to next contract occurs at 2012-09-13. | 2015-04-07 01:21:22 Date rule based rollover from /ESZ2 to next contract occurs at 2012-12-13. | 2015-04-07 01:21:22 Date rule based rollover from /ESH3 to next contract occurs at 2013-03-07. | 2015-04-07 01:21:22 Date rule based rollover from /ESM3 to next contract occurs at 2013-06-13. | 2015-04-07 01:21:22 Date rule based rollover from /ESU3 to next contract occurs at 2013-09-12. | 2015-04-07 01:21:22 Date rule based rollover from /ESZ3 to next contract occurs at 2013-12-12. | 2015-04-07 01:21:22 Date rule based rollover from /ESH4 to next contract occurs at 2014-03-13. | 2015-04-07 01:21:22 Date rule based rollover from /ESM4 to next contract occurs at 2014-06-12. | 2015-04-07 01:21:22 Date rule based rollover from /ESU4 to next contract occurs at 2014-09-11. | 2015-04-07 01:21:22 Date rule based rollover from /ESZ4 to next contract occurs at 2014-12-11. | 2015-04-07 01:21:22 Date rule based rollover from /ESH5 to next contract occurs at 2015-03-12. | 2015-04-07 01:21:22 Date rule based rollover from /ESM5 to next contract occurs at 2015-06-11. | 2015-04-07 01:21:22 |
[2015-04-08 01:49:42] |
Is this for an Intraday chart or Historical Daily chart?
[2015-04-08 01:51:00] |
The way to get more is to install another copy of Sierra Chart and set it to use the "Sierra Chart Historical Data Service" which uses two digit years. Refer to the instructions here: http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html#UsingSCHDS Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-08 03:10:03] |
This is a historical chart, I think a second copy using "Sierra Chart Historical Data Service" is very expensive (99.75 USD / month) because of the lack of a supported trading account. Earlier versions of Sierra Chart supported the 2 digit years allowing long term back adjusted charts using a trading account. The Symbol in Chart Settings allowed the entry of the 2-digit year, which it does not now.
[2015-04-08 06:20:34] |
Installing another copy of Sierra Chart and setting it to use the Sierra Chart Historical Data Service has no expense all. You can do that right now. We are planning to work on adding the capability to support further years of history with Historical Daily charts when using a trading service that only uses single-digit years. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-08 06:20:57
