Date/Time: Wed, 16 Sep 2026 01:37:46 +0000
Scale in question 2
View Count: 1166
| [2015-04-06 22:34:44] |
| onnb - Posts: 666 |
Say I have: sc.SupportAttachedOrdersForTrading = 0; sc.SupportTradingScaleIn = 1; I submit a buy market order and attached stop order from ACSIL. I now submit a buy Limit order from ACSIL. I assume that the stop would be incremented when the Limit order is filled? Should I have submit the Limit order with a stop or without one? (I want the working stop order to grow in quantity but price should stay at whatever values its currently at.) |
| [2015-04-06 23:28:08] |
| onnb - Posts: 666 |
I noticed that behavior is such that in order for this to work: 1. The second order *must* have a stop exit order defined 2. The price of the working order does not change regardless of the price with which the new stop is set. If this is indeed the case see this thread closed |
| [2015-04-06 23:40:56] |
Should I have submit the Limit order with a stop Yes.
