Date/Time: Sun, 22 Dec 2024 02:46:09 +0000
separating chartbooks
View Count: 873
[2015-04-06 21:47:02] |
User438810 - Posts: 50 |
I have 3 monitors and would like to detach chartbooks instead of individual chart windows from the main window. Ideally I would like one chartbook per monitor. Is there a way to do this? Thank you. |
[2015-04-07 04:19:56] |
No, this is not supported. Unless you install multiple copies of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
