Date/Time: Sun, 22 Dec 2024 03:31:38 +0000
Open Chartbook
View Count: 1004
[2015-04-06 11:08:34]
User847587 - Posts: 18
I saved chartbook files (.cht) under an older version to the d: drive. Now I need to load those files. The newer open chartbook file menu apparently does not show the d: drive. So I need help opening .cht files from the d: drive.
[2015-04-06 17:10:40]
Update to the latest prerelease with Help >> Download Prerelease.
On the File >> Open Chartbook window there is a "Folder" button you can use to change the drive and folder.
