Date/Time: Sun, 22 Dec 2024 03:31:31 +0000
Saved studies do not load
View Count: 942
[2015-04-05 16:35:05]
User439975 - Posts: 4
Hi, I use different studies for each timeframe cause i require different tools, therefore i have a set of saved studies for each timeframe.
when I try to load my pre saved studies after changing the time frames the don't load and are missing the saved items.
what can i do?
[2015-04-05 20:01:39]
Explain the step-by-step procedure you are following to do this: "when I try to load my pre saved studies after changing the time frames "
[2015-04-06 17:45:27]
Solved it, had to click "save all". Thanks.
