Date/Time: Sun, 22 Dec 2024 03:03:09 +0000
ES Chart has a few weird days which may be incorrect
View Count: 877
[2015-04-04 02:10:27] |
MKL17 - Posts: 35 |
This is probably a user error issue but I cannot figure out why there are a couple ES days that have little to no volume and appear to be incorrect. The link of the chart is here: http://www.sierrachart.com/image.php?l=1428113000818.png I am simply trying to get the most accurate daily ES chart using intra-day data. Other possibly relevant/incorrect? settings 1) Intraday Chart Only - 405 Minutes - 8:30 to 15:15:00 2) No load weekend data and no use evening session 3) Auto Rollover Futures Hope this is enough info. Thanks in advance. 4) Continuous Futures Contract - Volume Based Rollover, Back Adjusted |
[2015-04-06 10:34:13] |
It is best to switch the timeframe per bar down to 5 minutes to better isolate areas of any missing data. If you notice missing data, re-download the data following the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading If you still see something that does not look right, enable Chart >> Show Rollover Dates and let us know the particular time range and post an image of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-06 10:35:01
