Date/Time: Mon, 05 Oct 2026 02:31:39 +0000
Volume filter in Number Bars seems incorrect
View Count: 1215
| [2015-04-03 18:29:59] |
| User580215 - Posts: 1 |
I have setup a volume filter on a number bar chart to exclude <=99, and the 'filter trades completely' setting. The problem is that the trades/total volume/avg volume per trade don't make sense on any of the bars. For example there is bar where: Trades=151 Total Vol=614 Avg Vol/Trade = 4.1 Since I'm only including trades on the chart > 99 volume, if there are 151 trades the volume should be at least 151*100=15,100. The avg vol/trade should also have to be > 99 in all bars. Am I missing something? thanks! |
| [2015-04-06 19:02:05] |
Make sure you have a tick by tick data configuration: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
