Date/Time: Thu, 17 Sep 2026 03:29:03 +0000
Exporting Intraday Data
View Count: 1436
| [2015-04-03 12:56:55] |
| User94740 - Posts: 333 |
Hi SC, it seems the data being exported is in error. This is an excerpt: Date, Time, Open, High, Low, Last, Volume, NumberOfTrades, BidVolume, AskVolume 2014/9/19, 06:20:29, (null), 0.00, 90.90, 90.30, 1804353752, 1, 1, 0 2014/9/19, 06:20:29.1, 0.00, 90.90, 90.30, 90.50, 1, 1, 1, 0 2014/9/19, 13:03:50, (null), 0.00, 90.90, 90.22, 1804353752, 1, 1, 1 2014/9/19, 13:28:51, (null), 0.00, 90.90, 90.20, 1804353752, 1, 1, 1 2014/9/19, 13:31:13, (null), 0.00, 90.90, 90.20, 1804353752, 1, 1, 1 2014/9/19, 13:32:40, (null), 0.00, 90.90, 90.22, 1804353752, 1, 1, 1 2014/9/19, 13:32:40.1, 0.00, 90.90, 90.22, 90.24, 1, 1, 1, 0 Would appreciate your feedback, thx! |
| [2015-04-06 19:08:52] |
This has been corrected in Sierra Chart version 1243.
| [2015-04-25 19:53:41] |
Hi SC, I am currently running 1249 and still have the same problem with the data being exported. As you can see below: Date, Time, Open, High, Low, Last, Volume, NumberOfTrades, BidVolume, AskVolume 2014/10/13, 17:37:40, 0.00, 83.58, 83.50, 83.53, 1, 1, 1, 0 2014/10/13, 17:38:52, 0.00, 83.63, 83.50, 83.50, 1, 1, 1, 0 2014/10/13, 17:39:53, 0.00, 83.45, 83.28, 83.45, 1, 1, 0, 1 2014/10/13, 17:42:15, 0.00, 83.45, 83.38, 83.45, 1, 1, 0, 1 2014/10/13, 17:44:56, 0.00, 83.35, 83.32, 83.32, 2, 1, 2, 0 2014/10/13, 17:45:01, 0.00, 83.34, 83.28, 83.34, 1, 1, 0, 1 2014/10/13, 17:46:05, 0.00, 83.45, 83.29, 83.29, 1, 1, 1, 0 2014/10/13, 17:46:05.1, 0.00, 83.45, 83.29, 83.29, 1, 1, 1, 0 2014/10/13, 17:46:05.2, 0.00, 83.45, 83.29, 83.29, 1, 1, 1, 0 2014/10/13, 17:46:25, 0.00, 83.45, 83.30, 83.30, 1, 1, 1, 0 2014/10/13, 17:46:25.1, 0.00, 83.45, 83.30, 83.30, 1, 1, 1, 0 2014/10/13, 17:46:25.2, 0.00, 83.45, 83.30, 83.30, 1, 1, 1, 0 |
| [2015-04-26 15:03:51] |
| User65895 - Posts: 16 |
Actually, that's correct. The Open is empty. High is the current Ask. Low is the current Bid. Last is the last trade. I really wish the Export Bar Data to File, and the Write Bar Data study would export in this same format. |
| [2015-04-26 23:27:02] |
I have to question whether this info would be correct. If the data is tick data, then only one price should be reflected in the open, high, low, close. When one starts bunching them together as in a one minute chart, then there should be differences. What also worries me is the lack of volume. Even though my excerpt was taken at a time when oil is less active, there has to be more volume.
| [2015-04-27 01:18:20] |
The format of the data is explained at step 6 and 7 here: http://www.sierrachart.com/index.php?page=doc/doc_ImportExport.html#export The time zone of the exported data is UTC. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
