Date/Time: Sun, 22 Dec 2024 03:05:11 +0000
SierraChart - moving the application on an other PC
View Count: 968
[2015-04-03 07:34:11]
FerroTrader - Posts: 70
I would like to unistall SierraChart on my "machine A" and I would like to move it on my "machine B": how could I ? Is it enough to delete SierraChart folder under the C:\ directory ? will I have any problem with the serial once I move SierraChart on my machine B ?
Thank you a lot for you support.
Andrew
[2015-04-03 15:27:56]
Sierra Chart - Max - Posts: 5756
Refer to help topic 15 here:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
If you would not want to use Sierra Chart on a computer, then deleting the Sierra Chart Folder is sufficient.
Sierra Chart Support
Date Time Of Last Edit: 2015-04-03 17:06:48
