Date/Time: Sun, 22 Dec 2024 02:52:07 +0000
Flux sierra chart with the excell file
View Count: 1085
[2015-04-03 01:45:02] |
User76558 - Posts: 1 |
Hello i call you because i would like to have the flux sierra chart with the excell file. Have the market flux on the file excell as all are connected i am working with this website:( http://www.strategies-options.com/art/81-matrice-8options-global-trading.html )here it's this picture i want to connected. So now i use the transact flux with the broker infinity futures i thank you very much to tell me the procedure for do that Regards |
[2015-04-06 19:16:47] |
Refer to the documentation here for the Spreadsheet study feature: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html This might be what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
