Date/Time: Sun, 22 Dec 2024 03:04:21 +0000
[User Discussion] - Bollinger Band alert code not working
View Count: 1058
[2015-04-02 22:20:43] |
jivetrader - Posts: 410 |
using Color Bar Based on Alert Condition, this simple alert: L<ID107.SG3 where ID107=Bollinger Bands produces a signal when the bar low is below the price of 1.0900--nothing to do with the Boll Bands. same code applied to Color Bar Based on Alert Condition has the same result. please advise |
[2015-04-02 22:44:15] |
simple chart attached
color bkgd error.cht - Attached On 2015-04-02 22:44:04 UTC - Size: 38.45 KB - 474 views |
[2015-04-02 22:45:30] |
Sawtooth - Posts: 4141 |
Do you have 107 studies on your chart? Maybe there's a limit. This works: =L<ID1.SG3 where ID1 is the BB study Date Time Of Last Edit: 2015-04-02 22:51:18
[2015-04-03 00:32:23] |
tom, the attached chart template has only the 2 indicators and i get the same result. could you try it on your system please? see screenshot. Date Time Of Last Edit: 2015-04-03 00:34:13
color bkgd error2.png / V - Attached On 2015-04-03 00:34:10 UTC - Size: 55.69 KB - 351 views |
[2015-04-03 01:05:06] |
This is a Value Format issue. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#ValueFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
