Date/Time: Sun, 22 Dec 2024 03:20:38 +0000
Re-center Trade DOM Scales
View Count: 981
[2015-04-02 10:35:24] |
User246578 - Posts: 17 |
Hi there, Is it possible to keep "Re-center Trade DOM Scales" on all of the time instead of using a hotkey? Thank you |
[2015-04-02 18:01:18] |
Yes. Right-click on the scale of numbers and select Scale Range: Constant Range Auto Center
[2015-04-04 17:09:04] |
Thank you.
