Date/Time: Tue, 15 Sep 2026 11:01:59 +0000
Bulk Export of Intraday Data
View Count: 1348
| [2015-04-02 04:15:24] |
| ompipotent - Posts: 2 |
I want to export intraday data from many symbols to text. Right now, I'm using the "Edit -> Export Intraday Data to Text File" feature, but I'm prompted to specify a file name for each symbol each time I do the export. I would prefer to do a bulk export for all symbols I have worked with or for all symbols saved to a Chartbook and have each of the export files named after the symbol (e.g. TSLA.txt). Is there such a feature in Sierra Chart? Alternatively, is there an external script available to to accomplish the same thing? Thanks! ---danny |
| [2015-04-02 18:04:22] |
The only thing we can think of to automate this is to use program like Auto Hot Key.
