Date/Time: Tue, 22 Sep 2026 09:26:44 +0000
[User Discussion] - User Discussion: ACSIL for Gap studies
View Count: 3015
| [2015-04-02 03:55:11] |
| Kiwi - Posts: 375 |
Do gaps matter in your tradable? Recency often makes me think that they do for M1 HSI but a study will show you whether its true or not. Here's some code you can use in a dll (modify as you will) that shows gaps between close and the next low or high until they are filled or the day ends. Note that you'll need to change the hours ... mine is based on 2 hsi sessions. /***********************************************************************/ SCSFExport scsf_gap(SCStudyGraphRef sc) { SCSubgraphRef gtop = sc.Subgraph[0], gbot = sc.Subgraph[1], gp = sc.Subgraph[5]; SCSubgraphRef o0 = sc.Subgraph[7], o1 = sc.Subgraph[8]; if (sc.SetDefaults) { sc.GraphName="Gap"; sc.StudyDescription=""; gtop.Name="Gt"; gbot.Name="Gb"; gp.Name="Gap"; o0.Name="0"; o1.Name="1"; sc.DrawZeros=0; sc.GraphRegion=0; sc.FreeDLL = 1; return; } int i, j, gap; float gaph, gapl, gapc; SCBaseDataRef DIn = sc.BaseDataIn; int const hx = 1, lx = 2, cx = 3; for (i=sc.UpdateStartIndex; i < sc.ArraySize; i++) { gtop[i]=0; gbot[i]=0; int p=i-1; if((sc.BaseDateTimeIn[i].GetTime()>HMS_TIME(9,55,00) && sc.BaseDateTimeIn[i].GetTime()<HMS_TIME(12,30,00)) || (sc.BaseDateTimeIn[i].GetTime()>HMS_TIME(14,32,00) && sc.BaseDateTimeIn[i].GetTime()<HMS_TIME(16,15,00))) { int const lookback=2; gap=+1; gapl=DIn[cx][i-lookback]; gaph=DIn[lx][i-lookback+1]; for(j=i;j>i-lookback;j--) { // looking for gap up if(DIn[lx][j]<=gapl) gap=0; else if(DIn[lx][j]<gaph) gaph=DIn[lx][j]; } if(gap==0) { gap=-1; gaph=DIn[cx][i-lookback]; gapl=DIn[hx][i-lookback+1]; for(j=i;j>i-lookback;j--) { // looking for gap down if(DIn[hx][j]>=gaph) gap=0; else if(DIn[hx][j]>gapl) gapl=DIn[hx][j]; } } if(gap==+1) for(j=i;j>i-lookback;j--) { gtop[j]=gaph; gbot[j]=gapl; } else if(gap==-1) for(j=i;j>i-lookback;j--) { gtop[j]=gapl; gbot[j]=gaph; } gp[i]=gap; if(gp[p]==+1 && DIn[lx][i]>=gtop[p]) { gtop[i]=gtop[p]; gbot[i]=gbot[p]; gp[i]=gp[p]; } else if(gp[p]==-1 && DIn[hx][i]<=gbot[p]) { gtop[i]=gtop[p]; gbot[i]=gbot[p]; gp[i]=gp[p]; } } } } Here's what it draws. http://i.imgur.com/w9TREkG.png |
| [2015-04-02 05:46:17] |
| crazybears - Posts: 314 |
Hi Kiwi thanks for your code . is it possible to draw lines also for more than 1 day ? i mean if there is a gap yesterday or some day ago that isn't already closed . thanks. |
| [2015-04-05 07:48:57] |
| Kiwi - Posts: 375 |
Yes. You can take the code and alter it to do pretty much whatever is important to you.
