Date/Time: Sun, 08 Sep 2024 00:10:15 +0000
Detaching Windows
View Count: 785
[2015-04-02 00:31:05] |
User838227 - Posts: 4 |
Which service packages enable me to detach my windows? I know Package 5 enables that feature, but do packages 1 and 3 also enable it? Thanks. |
[2015-04-02 03:04:04] |
This is supported on all service packages now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
