Date/Time: Sun, 08 Sep 2024 00:17:09 +0000
Chart Trading Order Lines Conflict With Drawings
View Count: 743
[2015-04-01 23:24:29] |
Trader Ra - Posts: 87 |
Hi, when trading directly off the charts, being able to always see order lines (whether its pending, filled or attached) is crucial. Currently, if if i uncheck 'Draw non-highlight drawings underneath.. ' option, seeing the actual order lines become a problem. The order lines are displayed underneath the non- highlight drawings like lines. The only way to have order lines drawn above all other drawings is to check the above option (if Im not missing something). This solves the order line issue but then makes using non-highlight drawings a problem on the charts like markers, lines, etc. I have tried adjusting order line widths, etc under graphic settings but this doesn't really work well. Still looks confusing on the chart. I hope that explains the issue. If you want, I can upload a screenshot to demonstrate. What's SC's take on this? Is there a work around for this issue or something SC can look at modifying so that all order lines (very important) are always on top of all studies and drawings regardless chart settings? Thanks. |
