Date/Time: Sun, 08 Sep 2024 00:19:03 +0000
second copy of SC with data feed?
View Count: 784
[2015-04-01 19:10:12] |
freestyler - Posts: 35 |
Hi: Is this possible: Running of a copy of SC with IB as broker, and SC exchange data feed on PC with no problems. Want to run a second copy of SC on my laptop (at the same time as PC running SC + IB), without IB, but with SC exchange data feed, so I can do some testing and such. I tried it but keeps getting "download failed" error. Thanks. Mark |
[2015-04-01 19:30:43] |
Did you just want to access historical data on the other computer?
[2015-04-01 20:01:52] |
No, I meant real time data on the second computer.
[2015-04-01 23:01:42] |
Did you want to access real-time data for the CME?
[2015-04-01 23:42:27] |
Yes, I trade mostly futures.
[2015-04-02 00:23:24] |
OK, but it is not possible to access CME data without a trading account connection unless you pay substantially higher exchange fees.
