Date/Time: Sun, 08 Sep 2024 00:16:33 +0000
Mini Futures
View Count: 922
[2015-04-01 19:05:50] |
User39772 - Posts: 311 |
Hello, I activated "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts". If I want to load the NQ, ES, YM Mini Futures, how do I have to proceed, should I use the symbols used in the TWS ? I want to make sure that the feed comes from SC not from IB ! |
[2015-04-01 19:31:35] |
Yes, you do need to use the Interactive Brokers symbols and be connected to Trader Workstation. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-01 19:32:17
