Date/Time: Sun, 08 Sep 2024 00:10:28 +0000
Stop Limit Orders
View Count: 833
[2015-04-01 15:19:06] |
User428971 - Posts: 26 |
How do I create an order where the stop and limit order prices are the same. Example, buy YM on a stop limit at 17180, whereby the stop is 17180 and the limit is 17180.
[2015-04-01 17:58:47] |
For this you need to use the Stop-Limit order type: https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#StopLimit And as explained you need to set Set >> Stop-Limit Order Limit Offset on the Trade Window for the chart to 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
