Date/Time: Sun, 08 Sep 2024 00:17:27 +0000
Retrieving data
View Count: 861
[2015-04-01 14:36:54] |
User61628 - Posts: 1 |
Hi I had an issue with candles gapping, so I "Deleted all data and download" However now, I cannot get data further back than when I now reopened the charts ie, like 10 mins ago Please help! |
[2015-04-01 15:49:19] |
If you are having a problem doing something with Sierra Chart, then please copy and paste the ENTIRE copy of the Message Log into your email message or Support Board message. Support cannot help without the Message Log. Sending some of the lines is not helpful. The message log does not contain any private information. Instructions: 1. If the Sierra Chart Message Log is not already open, then select "Window >> Show/Hide Message Log" on the menu to open it. If you still do not see the log after selecting this command, then select "Window >> Reset Windows". The log will be displayed in this case. If not, then select "Window >> Show/Hide Message Log" again. 2. Press the "Copy Log" button on the Message Log window. Do not use the "Send for Analysis" button. Otherwise, the log will not be seen. 3. Go to your e-mail message or your Support Board message. Point to the area where you type your message. 4. Right-click your mouse pointer. Select "Paste" on the menu to paste it into the message. THE INSTRUCTIONS ABOVE EXPLAIN HOW TO AUTOMATICALLY COPY AND PASTE THE MESSAGE LOG DATA INTO A MESSAGE. THERE IS NO NEED TO TYPE IT BY HAND. Sierra Chart Support |
