Date/Time: Sun, 08 Sep 2024 00:16:53 +0000
Quick question regarding ACSIL
View Count: 946
[2015-04-01 13:20:31] |
Shaharabin - Posts: 28 |
Hi there, Is it possible to implement a Lua script inside a custom indicator i wrote using ACSIL? Thanks, Shahar. |
[2015-04-01 15:39:51] |
There is no direct support for Lua within ACSIL.
Sierra Chart Support |
[2015-04-01 18:49:32] |
It is possible to make a call to an external DLL (Dynamic Link Library): https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#DLLCalling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-01 19:56:55] |
Thank you!
