Date/Time: Wed, 14 Oct 2026 19:36:24 +0000
Number bar tick issue ??
View Count: 1289
| [2015-04-01 11:38:59] |
| JingIt - Posts: 44 |
I'm using Jigsaw tool on OEC platform and using OEC data feed for sierrachart, I found that Number bar have recorded the same volume as jigsaw, but the number bar show the tick side different from jigsaw even both using OEC datafeed. Is there any issue with data feed or OEC limit the data to Sierrachart or Sierrachart print it incorrectly?? Please start video from 2:02 screencast.com/t/R5SAXN6hukcS Date Time Of Last Edit: 2015-04-01 11:50:46
| [2015-04-01 18:30:00] |
For an understanding of how Bid volume and Ask volume are determined in Sierra Chart, refer to: Numbers Bars: Definitions For accuracy, you need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
