Date/Time: Sun, 08 Sep 2024 00:17:35 +0000
Quoteboard and Google Financial Data
View Count: 834
[2015-04-01 06:57:34] |
Acro - Posts: 437 |
Am I right in assuming that the Google supplied data is incompatible with the quoteboard and its only purpose with that feed would be a way of linking many symbols to a chart ? Thank You |
[2015-04-01 18:53:22] |
Yes, this is correct.
