Date/Time: Fri, 11 Sep 2026 19:43:44 +0000
System configuration required for Tradeguider
View Count: 1550
| [2015-04-01 04:24:10] |
| User279714 - Posts: 21 |
Dear Sir, I have a few questions regards Sierrachart while using with Tradeguider Vsa plugin and sequential scanner. I would like to use the SierraChart to monitor and scan 150 stocks and 150 futures at a time of Indin stock market. 1)In each chartbook i would like to open a 5 minute, 15 Minute, 1 Hour, 4 Hour, 1 day, 1 Week, 1 Month Chart along with a sequential scanner. What is the configuration of the computer required to open all the 300 chartbooks with the 8 charts each . 2) when i subscribe to Globaldatafeed.com Can each chartbook have data of intraday and eod data in same chartbook . 3)Can this be run on amazon Aws along with Globaldatafeed.com. 4) Can Point and figure chart be used with version 1 5) Can you please extend my traial Date Time Of Last Edit: 2015-04-01 04:29:43
| [2015-04-01 19:34:50] |
1. This is hard for us to say. In general the computer should have at least 4-8 GB of memory and have at least a quad core CPU. 2. Yes. 3. If you are referring to a server, as long as the server is running Windows this will work. 4. Sierra Chart service package 1 supports the Point and Figure chart study. 5. The trial has been extended. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
