Date/Time: Thu, 17 Sep 2026 02:30:44 +0000
Volume on Number of Trades Per Bar
View Count: 2109
| [2015-03-31 20:04:50] |
| User558737 - Posts: 3 |
I cannot get the "volume" study to display correctly on a Number of Trades Per Bar Chart. Most of the bars are pegged to the top of the study area. Am I missing something.
| [2015-03-31 20:12:30] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-01 14:37:54] |
http://www.sierrachart.com/image.php?l=1427898924774.png |
| [2015-04-01 18:48:11] |
Since this market is a CFD, where every trade has a volume of 1, the volume display is correct on this being the chart is set to a fixed number of trades per bar.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-01 18:48:24
| [2015-04-02 15:35:48] |
Still don't understand. If I convert the Number of Trades Per Bar chart to a time based chart I get volume. Also I can get Bid or Ask volume on the Number of Trades Per Bar chart. http://www.sierrachart.com/image.php?l=1427988852546.png |
| [2015-04-02 18:00:39] |
More information about this is documented here: Sierra Chart Real Time and Historical Forex and CFD Data Service: Volume Data for Forex and CFD Markets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
