Date/Time: Fri, 22 Nov 2024 18:42:03 +0000
sc.UseTool()
View Count: 1763
[2013-05-30 16:40:18]
SoundsLikeSun - Posts: 30
When using sc.UseTool(), with DrawingType = DRAWING_TEXT, it makes a line of text appear on the graph.
Is there a way to determine the height of this line in terms of ticks (which can dramatically change depending on the timeframe).
I need this value to keep my charts clean and avoid the overlapping of text from different sc.UseTool requests.
Thank you for your answer,
Thomas
[2013-05-30 20:44:18]
You can only control the height of text through the s_Usetool::FontSize member and this controls the height in what are called Points. This is a Windows unit which is translated to pixels based upon the DPI setting for the system.
[2013-05-31 20:19:00]
OK
Thank you for your fast answer
