Date/Time: Thu, 09 Jan 2025 19:20:27 +0000
[User Discussion] [Locked] - Invert Image 180%
View Count: 1389
[2015-03-31 15:38:50] |
User94740 - Posts: 333 |
Hi SC, is it possible to invert the image?
[2016-07-25 16:33:25] |
hi sc, have yet to hear anything new since 31 March 2015 about this issue except according to one of your latest release updates. Could you please give a status according to importance of completion? thx as always! 1316 Release Date: 2015-10-26 Corrected some low-level issues with the updating of controls on the Trade Window related to recent changes to support Trade Window linking. Removed unnecessary logging related to HTTP communication. Continued development to support the Chart >> Chart Settings >> Invert Prices option. This option is still not yet fully implemented. |
[2016-07-25 16:58:26] |
You did not get an answer because the question did not make any sense to us. We do not understand what you meant by inverting an image by a specified number of degrees. From our perspective it came across as an unreasonable request and these will get no attention from us. Chart >> Chart Settings >> Invert Prices has been fully implemented except for when trading. Did you test it? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-25 17:00:16
[2016-07-25 17:01:23] |
yes, just now, but it looks bad. Before/After chart pics attached http://www.sierrachart.com/image.php?Image=1469465994768.png http://www.sierrachart.com/image.php?Image=1469466038352.png |
[2016-07-25 17:06:39] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ResetScales And do not use Range bars when inverting the prices. If you do not know how to set the range properly that is not something we are going to help with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-25 17:11:13] |
ok, thx
[2016-07-28 18:44:05] |
PS do you foresee this functionality working with range bars?
[2016-07-28 18:47:59] |
You can use Range bars. Make sure you set the range correctly. That is all. You just have to look at the prices and determine what the appropriate range is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-28 18:48:22
[2016-07-28 18:52:20] |
Here is an example: http://www.sierrachart.com/image.php?Image=1469731879823.png Refer to the documentation for Invert Prices: Chart Settings: Invert Prices (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-28 19:58:38] |
super!
[2016-08-08 12:30:36] |
I had too much trouble with the function "invert price" in the chart settings, but I have been able to get the price inverted using a price/study overlay. I was able to invert the volume study as well, but am having trouble with inverting Volume by Price. I get nothing. I was also wondering, if it is possible to flip the image by a graphic's setting and then adjust accordingly so that price is readable? I have also tried to set the volume at price multiplier in the chart settings to -1, but it changes to 4294967295.
Date Time Of Last Edit: 2016-08-08 12:36:13
[2016-08-08 15:59:14] |
You cannot invert the Volume by Price. In general, you are only creating trouble for yourself by using that setting. If you are having difficulty do not use it and it is not something we are willing to provide any further support on. We have to make that clear. We are not providing any further support in this regard. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-08 16:00:47
[2016-08-08 18:34:46] |
Actually we need to make a correction, it is possible to invert the Volume by Price study by using the Invert Prices option in Chart >> Chart Settings but you need to set the Tick Size in Chart Settings to correspond to the price changes. Sierra Chart does not determine what that will be and therefore in some cases you will not get a correct display for Volume by Price. If you cannot figure out what the correct Tick Size is, it is not something we will help with. You should be more than capable of determining that on your own if you are deciding to invert prices to begin with. You should understand what you are doing. When using the 1/Price study, the Volume at Price data is not inverted and that is where the problem is. But that is not what is being used in this case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-08 18:36:20
