Date/Time: Sat, 03 Oct 2026 08:13:46 +0000
Sierra Chart doesn't start
View Count: 1236
| [2015-03-31 02:48:32] |
| martintokman - Posts: 7 |
Hi, i have installed the software from the software donwload web of sierra, i have installed the version With Old SpreadSheets, i am an old user of sierra that has to reset windows and install it again, the install process goes without any problem but when i try to run sierra chart the program never starts, it does nothing. I have windows 7 installed on my computer, this is a fresh installation of windows. could you please help me? best regards |
| [2015-03-31 08:26:32] |
This means you have to install Microsoft .NET 4 on your system when using Old Spreadsheets. Run a Google search for this to get the download link from Microsoft.
| [2015-03-31 13:28:24] |
thanks a lot, the problem is now solved.
