Date/Time: Tue, 08 Sep 2026 22:54:06 +0000
Can we disconnect 1 chart book and leave another connected at the same time?
View Count: 1592
| [2015-03-30 17:16:53] |
| User48557 - Posts: 138 |
When I have too many different chart books open at once my computer tends to overload and shut down, to avoid this i am wondering if there is a way to have 2 chart books open at once but one chart book is not connected .
| [2015-03-30 17:32:47] |
No, but this would not make a CPU difference of any significance. What does make a difference is minimizing a chart window because it removes the graphics load from it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-03-31 12:43:28] |
| User52239 - Posts: 13 |
Does mimimizing the window help on the inactive chartbooks as well ? Or just on the active chartbook ? |
| [2015-03-31 18:05:54] |
If a Chartbook is not visible, there is no graphics load from it to begin with.
| [2025-02-14 19:48:05] |
| User837393 - Posts: 161 |
Hello, On that note, is there a way to disconnect one (or a set of chart) in a Chartbook from the datafeed ? The objective would be to minimise data latancy ? |
| [2025-02-14 19:55:12] |
| John - SC Support - Posts: 47806 |
There is still no way to do what you are asking. Any open chartbooks are going to be downloading the necessary data for the charts and processing any studies.
| [2025-02-16 17:40:58] |
| ForgivingComputers.com - Posts: 1238 |
On that note, is there a way to disconnect one (or a set of chart) in a Chartbook from the datafeed ? The objective would be to minimize data latancy ?
You could open another instance, update the charts, and disconnect the feed. Obviously, the charts won't get updated unless you reconnect. |
